Old 09-08-2017, 03:17 PM   #1
prodjsaig
bathroom tile question and cement board
hi hope everyone is having fun keeping busy always figuring out another way to do something.
i am wondering if it is possible to tile my second bathroom. I got the first one out of the way. It is 3/4 ply over 2x10 16' on center with 1.5" lightweight concrete.
I realized I may not be able to tile this bathroom because there is a slight height difference in one of the cracks. picture attached shows where the difference is.
when I took the old vinyl floor out the builders used a 2x12 around the toilet flange. it was all cracked and warped so I replaced with a second layer of 3/4" ply and durock cbu with thinset. the other bath I used 2 extra layers of 3/4" instead of the cbu on top.
its a 5x6 bathroom with tub. so its a small span and when I jump around a bit I dont feel the crack move. what are my chances if I fill the uneven parts with slc and tile with redgard or equivalent? or should I skip the tile alltogether?
Colby
prodjsaig is offline   Reply With Quote
Old 09-08-2017, 04:47 PM   #2
Usually, if one side of the crack is higher than the other side, tile is not recommended. If I had to guess, the plywood under the SLC got wet and swelled, causing the SLC to crack. How long is that crack?
Old 09-08-2017, 10:13 PM   #3
prodjsaig
It goes all the way to the corner of the room. looks like removing the lightweight concrete while doing a tub removal would be appropriate. so Ill just go with the vinyl tile which is pretty durable a lot better than laminate IMO
Colby
Old 09-08-2017, 11:16 PM   #4
Hi, Colby.
Purely as comedy, all the pros who see your egg-beater mixer are cringing at the build-up and are screaming for you to clean it off.
Bathtub Tile surround cement board question v4tuna Tile Forum/Advice Board 4 04-15-2011 01:28 AM
Cement board question Telstrot Tile Forum/Advice Board 7 09-09-2006 09:51 AM
Cement Board Question statjunk Tile Forum/Advice Board 3 05-05-2006 09:52 PM
Question about cement board. Sandy Tile Forum/Advice Board 6 03-16-2004 01:40 PM
cement board question focus57 Tile Forum/Advice Board 1 10-05-2003 08:17 PM
