Old 09-07-2017, 09:20 PM   #1
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
How would you turn this tub into a shower?
I was asked by a client if I could turn this tub into a shower without changing too much stuff. My answer to her was mostly a "no" but I also told her that i would ask the boys for design suggestions.
The tub is in a house that was built in the 1930's. She says that it's original to the house but i don't know that is true. She was hoping for a way to get water up to a shower head. I mentioned to her that the walls are not waterproof and that the current tile probably isn't water proof either.
My thought is to tear it out, frame in a wall, run the plumbing to a shower head, prep everything for tile.
The answer has to be no, but I need to ask. Are there any as is options on turning this into a shower.
Check it out.
I am neither clever nor funny
Travis
It's just a clever handle.
Old 09-07-2017, 09:54 PM   #2
Gotta put a shower head somewhere. Outside of moving the valve to the other end and putting glass on that low wall, I don't see any way around framing that wall to the ceiling, or at least high enough to set a shower head.
Old 09-08-2017, 03:51 AM   #3
JerseyDIYguy
How about a hoop shower curtain rod similar to one of these:
http://www.homedepot.com/b/Bath-Bath...vZcfvvZ1z0vaaz
You'd likely use 2 extended length curtains to create a complete enclosure (I've seen this in old houses with claw foot tubs). The two curtains would meet directly over the shower valves to allow access to the valves.
Then you'd need to make an access hatch to the plumbing valves on the toilet side of the stub wall. Depending on the existing valve configuration you'd modify the plumbing (and maybe replace the valves) to accommodate a shower feed pipe going up through the top of the stub wall to a shower riser pipe - some ideas here:
http://www.homedepot.com/b/Bath-Bath...s/N-5yc1vZbrii
You'll probably need to change the tub spout to one with a diverter.
There are also kits where you can run all the shower riser plumbing directly off of a tub spout so you wouldn't even need to get inside the stub wall:
https://www.plumbingsupply.com/convertoskits.html
It's not the high tech solution, but you get to keep almost all the existing tile and walls as-is (I'm aware this qualifies as blasphemy on a tile forum).
Warren
Old 09-08-2017, 05:35 AM   #4
Redlands Okie
Acrylic, fiberglass FRB, or custom made to fit such as ONXY panels sold at box stores or glass panels (opaque) or combination could be set on all three sides of the existing tile. Right up against the wall as needed. Glass door or shower curtain for entrance. Shower head on a flexible hose or fixed pipe attached to a new faucet spout with a diverter and top connection for the hose. Glass company can drill holes in the glass to hang the flexible hose head or install a plate the width of the shower unit made out of the same stainless steel as the rest of the frame. JesrsyDIYguy ideas also a neat idea with little modifications needed and easy to remove at a later date if needed. Easily doable project.
Robert
Old 09-08-2017, 05:39 AM   #5
Add kerdi or hydroban foam panels to the walls for waterproofing, then install a giant single tile on each wall, then paint the room to match the large tile. Everything will look the same and solve your problems.
Old 09-08-2017, 10:15 AM   #6
Shady at Best
Tyrone shoelaces
Okay. Thanks for the suggestions.
Jersey diy, ideas like that are exactly why i decided to post. I figured there was nothing that could be done besides tearing it out and starting over.
Travis
Shower's Tile Grout Will Not Turn White! sagosto Cleaning, Restoration and Sealing 6 01-28-2017 10:50 AM
Shower re-tile...will this turn into full demo and new start Grimah1w Tile Forum/Advice Board 19 07-15-2012 02:24 PM
to turn pro or not turn pro, that is the question jeff in indy Professionals' Hangout 21 04-13-2011 10:28 PM
Help shower floor didn't turn out like we wanted Kenr Tile Forum/Advice Board 6 05-04-2006 07:23 PM
Turn a 5x7 bathroom into a shower intoit Tile Forum/Advice Board 28 02-06-2005 10:22 AM
