Old 09-06-2017, 06:37 PM   #1
Geno Woodlands
Has anyone seen, heard of this CURB technique?
Had 2 upstairs bathroom remodels where the tubs were converted to full showers. The vinyl liner on the curb side extended to the edge of the tile then went straight down and stopped. The "curb" was 2 pieces of wood covered on the top and outside with backer-board. The "curb" was then covered with an inside,top,and outside piece of marble. The "water-proofing" from the inside of the shower was to be achieved by silicon caulking the edges of the inside marble to the floor of the shower and up the sides. Needless to say, we had water pouring into the downstairs with both showers via light fixtures on the first floor. (Apparently there was no "pan" test) Contractor and his plumber said we just needed more silicon caulking. From what I've learned on this excellent website, it looks like I need curbs with the liner coming up and over. Has anyone had experience with this type of curb situation. I've included some pictures below. Thanks Geno Woodlands.
Geno
Geno Woodlands is offline   Reply With Quote
Old 09-06-2017, 06:59 PM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
You mean boogerin'? Yep, way to much experience with that here, I'm afraid.
You're right about needing the unpenetrated liner over the curb. If more caulk is the answer, well, it should never be the answer.
Looks to me like they tried to engineer a simpler system of curb building and failed miserably.
This is not something you should pay for BTW.
Peter
Old 09-06-2017, 07:10 PM   #3
Welcome, Geno.
What Peter said.
I don't understand the following:
What is the red material in the last photo? The little piece of gray material at the end of the curb is your pan liner? With the screw though the CBU on the inside of the curb?
Old 09-06-2017, 07:16 PM   #4
Geno Woodlands
Sorry about the picture orientation. The "red" is a painted 2x4 board. In the 4th picture, the shower is to the top and the bathroom floor is to the bottom. (The shower floor is higher than the bathroom floor). The liner comes out from below the shower tile floor and wraps under the red 2x4 board.
Geno
Old 09-06-2017, 07:18 PM   #5
Geno Woodlands
The 3rd picture is taken from the inside of the shower looking out to the bathroom floor. You can't see the liner in this 3rd picture as it is under the tile of the shower floor but it comes out and wraps under the red 2x4.
Geno
Old 09-06-2017, 07:24 PM   #6
rmckee84
Thats funny, they tried to waterproof the 2x4s...you can add a case of silicone and you'll still have issues. In the end you have a failed shower pan.
Ryan McKee
Old 09-06-2017, 07:29 PM   #7
Geno Woodlands
The last picture is taken from the bathroom floor looking up to the shower on the right. The horizontal pensel mark is level with the floor of the shower.
Geno
Old 09-06-2017, 08:27 PM   #8
Carbidetooth
Hmmmmm
For clarity, Geno, I drew this cross section as I understand your photos and description. Doesn't show CBU, but is this kinda what they left you?
Peter
Old 09-06-2017, 08:33 PM   #9
Geno Woodlands
Yes. That's it. Shower to the left -- bathroom floor to the right. Here's some photos that give bigger perspective.
Geno
Old 09-06-2017, 08:34 PM   #10
Geno Woodlands
Taped over shower drain.
Geno
Old 09-06-2017, 08:41 PM   #11
Geno Woodlands
But the tile /pan end at the 2 pieces of wood
Geno
Old 09-06-2017, 10:47 PM   #12
The only thing that will improve that shower is a sledge hammer.
Excuse my smoker's cough. [hack, hack, hack]
Old 09-07-2017, 02:42 AM   #13
JerseyDIYguy
Sorry to say it, but what you have is completely improper. There's also no truly acceptable way to fix it without tearing your floor (and likely walls) apart. The liner MUST go up and over the curb, never under it.
Warren
Old 09-07-2017, 06:49 AM   #14
Dave Gobis
da Man!
Dave Gobis's Avatar
That is most assuredly not going to work.
Old 09-07-2017, 07:00 AM   #15
What the others said. Not sure how they thought this would hold water.
Ever heard of this? KMaryP Tile Forum/Advice Board 1 08-04-2007 10:43 PM
Has anyone ever heard of........... ih8backerboard Professionals' Hangout 11 07-30-2007 08:21 AM
Ever heard of or used this? JohnP Tile Forum/Advice Board 1 01-26-2007 08:40 PM
anyone heard of this?? kawa135 Tile Forum/Advice Board 4 02-15-2006 07:25 AM
ever heard of this justin savage Professionals' Hangout 7 03-10-2005 06:40 AM
