Old 09-05-2017, 10:54 AM   #1
Dbor
Accent piece MUCH thicker than wall tile
I have a customer who wants to use an 8"x8" encaustic tile as the accent strip. A problem though it is much thicker than the wall tile. The encaustic is 10/16" while the wall is 5/16". How should they address this?
My thinking is laying a layer of 1/4" cement board on top of the 1/2" standard for the wall, soley underneath the wall tile.
Thoughts?
David
Dbor is offline   Reply With Quote
Old 09-05-2017, 12:04 PM   #2
What's the application, shower, or outside the wet area, or something else? What is the current substrate?
Old 09-05-2017, 12:43 PM   #3
CaliGrown
CaliGrown's Avatar
Two rows of dome liners
Chris (the young one)
Old 09-05-2017, 02:14 PM   #4
evan1968
Not So Senior Contributor
evan1968's Avatar
That right there...☝
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Old 09-05-2017, 05:19 PM   #5
Dbor
Shower wall. Down to the studs at the moment.
David
Old 09-05-2017, 05:26 PM   #6
HS345
Tile Contractor
HS345's Avatar
I would use 3/16" Kerdi Board before I'd use 1/4" cement board. No fasteners, much flatter.
The name's Greg
Old 09-05-2017, 08:02 PM   #7
PetrH
There is no reason the accent has to be the same thickness as the field tile, you just might have to leave a channel for the glass. You can use Quadeck or stone pencils to outline the strip if the edges of the tile are not aesthetically pleasing.
Petr
Old 09-12-2017, 05:33 PM   #8
Dbor
The edges are not appealing at all, as they are cement tiles, and especially since these tiles will put up against a glossy ceramic.
We were able to do a dry lay out here in the store and it was a pretty sharp look.
David
Help: Used wall tile as accent border on floor JGH2016 Tile Forum/Advice Board 9 08-23-2016 09:43 AM
Wall flanges thicker on new tub bcullins Tile Forum/Advice Board 3 09-14-2013 08:59 AM
Anybody channeled Wedi for thicker accent tiles? Topspin Professionals' Hangout 16 02-20-2013 09:04 PM
Grouting tumbled travertine tile accent piece DIYer4sure Tile Forum/Advice Board 4 10-17-2012 12:12 PM
Thin & Thicker tiles on same wall Unregistered Tile Forum/Advice Board 5 12-20-2004 03:28 PM
