Old 07-28-2017, 09:44 AM   #16
Scottly,
1- I'd chip out the drain, replace that, then drypack the new floor to the desired pre-slope height.
2- If you are concerned about drywall hitting concrete* use ceement board. Use only one waterproof layer. The kerdi or the sheet plastic.
3- Skip the pre-formed pan and solve all your problems at once with drypack.
* If you have slab moisture damaging your drywall, you have much larger issues to deal with.
Old 07-28-2017, 10:36 AM   #17
I'd do the same, replace the drain and ditch the Kerdi pan.
Old 07-28-2017, 01:28 PM   #18
scottly
Makes sense. Never did a dry pack floor, but no time like the present to learn it. Thank you gents.
Scottly
scottly is offline   Reply With Quote
Old 07-28-2017, 01:35 PM   #19
A mudbed is sort of like working with wet beach sand. You place it, pack it, and can shape it. It stays porous because of all of the sand and lean cement mixture. Even if you make a mockup and do a trial one, it is inexpensive. Your second one will go much faster and be better, but often, the first one is fine.
Old 07-28-2017, 08:13 PM   #20
Mathman
It's not too hard to do the mud floor. I did okay on my first attempt. There are some good tutorials about mixing it on this site. Read them and follow them and you will have better success. Get a helper to mix. My son helped me and other than working to get the mixture correct it was a big help.
Kirk
Mathman is offline   Reply With Quote
Old 07-29-2017, 07:59 AM   #21
diddly
Nother one
See my reply to Florida Sunken Shower (ugh) post of today.
Bookie
Bookie
diddly is offline   Reply With Quote
Old 07-29-2017, 10:43 AM   #22
Also, check out the "shower construction info" thread in the liberry. Lots of info there.
Old 07-31-2017, 11:24 AM   #23
scottly
Level line question
I know I'm over-thinking this, but I have a machinest background, not a plumbing/tile background, so please set me straight. Shower dimension is 54x32. If I slope to a level line at 1/4" per foot, my level line will be roughly 1/2" higher than center on the long ends. Do I leave the short ends the same? That results in a higher taper than the long ends???? Won't that look kinda goofy?
Scottly
Old 07-31-2017, 12:06 PM   #24
HS345
Tile Contractor
HS345's Avatar
Hi Scottly, you measure the farthest point from the drain and slope 1/4" per foot from there. Yes, the shorter distances will be a bit steeper, but there's really no way around it. You want a level perimeter.
The name's Greg
HS345 is online now   Reply With Quote
Old 08-01-2017, 06:52 AM   #25
scottly
Thank you!! Makes sense.
Scottly
Old 08-02-2017, 02:33 PM   #26
scottly
Sakrete says if you can't tile within 16hrs of hardening, you need to wait 28 days. Can someone explain that to me? I don't see it mentioned on this site in the mortar bed posts.
Scottly
Old 08-02-2017, 02:38 PM   #27
Sackrete says that about what, Scottly?
Old 08-03-2017, 04:54 AM   #28
scottly
Save time and scroll to bottom. http://www.sakrete.com/blog/creating...krete-sand-mix
Scottly
Old 08-03-2017, 10:39 AM   #29
scuttlebuttrp
He's referencing the note after the article from sakrete. Never saw that anywhere. Do you have cast iron pipes? Does the shower drain well?
Old 08-03-2017, 06:22 PM   #30
scottly
ABS drain pipe....drain has worked well. I got lucky tonight....I was cutting the pipe for the Kerdi drain....and chseling out around it...and I see a copper water line 2" from the drain pipe. God was watching over me as Iissed it with the chisel.
Scottly
Question about TR-420 (rebuild bottom of a shower pan) Tiger Mountain Tile Inc Professionals' Hangout 0 08-06-2015 06:08 PM
Shower Rebuild - Vapor Question JDinMI Tile Forum/Advice Board 4 01-30-2014 09:04 PM
shower rebuild Tim K Tile Forum/Advice Board 2 05-14-2007 05:38 PM
Florida Tiles Pietra Art Question Orlando Tile Forum/Advice Board 3 01-26-2005 01:18 PM
