Old 09-07-2017, 09:59 PM   #106
branimal
Jake
How big should the gap be between the bottom of the wall tile and the floor tile.
I'm using 3/16 grout lines. Is that the gap I should shoot for?
Jake
branimal is online now   Reply With Quote
Old 09-07-2017, 10:07 PM   #107
That'd be fine, Jake. Nothing less than 1/8th of an inch there.
Old 09-07-2017, 10:43 PM   #108
branimal
Jake
Thanks cx. Fill in the void with silicone?
Jake
Old 09-07-2017, 11:10 PM   #109
If this is in a wet area, yes, that would be my recommendation.
Old 09-11-2017, 05:33 PM   #110
branimal
Jake
How do I remove dried up mortar from
1) tile
2) between tiles
Jake
Old 09-11-2017, 06:23 PM   #111
A hand held grout saw works to lower the thinset in the joints. Just be careful not to let it get out onto the face of the tiles.
It's much easier to remove when the thinset is wet. Have a sponge and bucket of water handy while tiling and keep it wiped out.
Old 09-12-2017, 07:19 AM   #112
branimal
Jake
How tight do you guys make inside corners. I cut mine with 1/16 gap or maybe less. Is that too tight?
Jake
Old 09-12-2017, 09:21 AM   #113
1/8" is pretty good, since you need to be able to get caulk in it. If the caulk is just on the surface, it won't hold as well. You need just a little space for expansion as well.
Old 09-12-2017, 03:29 PM   #114
branimal
Jake
Kman - tile can expand??
I think my corner gaps are 1/16 or tighter 32. Basically jammed into the corners.
I'll sure to make all remaining corners 1/8".
Jake
Old 09-12-2017, 04:14 PM   #115
rmckee84
Its more the various building materials used in framing and covering the walls expand and contract at various rates.
Ryan McKee
Old 09-12-2017, 05:14 PM   #116
branimal
Jake
I managed to slip my margin trowel in that crack and widen it to 1/8". Thanks guys!
Jake
Old 09-12-2017, 07:34 PM   #117
But yes, Jake, your tiles can expand.
Old 09-19-2017, 04:35 PM   #118
branimal
Jake
Thinset question for you guys: I've used both customs buildings natural stone lft mortar and versabond lft mortar during my project.
(LFT = large format tile)
I find the versabond hardens way faster and becomes difficult to remove from the tile much more quickly than the natural stone mortar. A bucket of versabond also becomes rock hard and unusable much faster than the natural stone mortar.
Why is that? Should I be using one vs the other?
Jake
Old 10-02-2017, 06:40 AM   #119
branimal
Jake
Tiling an 9x 8 bathroom
Tiling my bathroom.
How long after I set tiles on the floor can I move my tile saw and stand on top of the set tiles? I need to reposition the tile saw halfway through the job to tile the entire bathroom.
It's a harbor freight 10" Brick saw and stand so they are pretty heavy.
The mortar says light traffic and grouting within 24 hours.
Cutting inside of my bathroom is the only option.
Jake
Old 10-02-2017, 05:21 PM   #120
rmckee84
48hrs is safe
Ryan McKee
HELP! The guy is tiling our bathroom now. Jimk75 Tile Forum/Advice Board 58 05-05-2014 01:12 AM
Tiling in bathroom jvandal Tile Forum/Advice Board 1 01-23-2010 09:12 AM
Tiling a Bathroom. Wow need HELP!! NotaPro Tile Forum/Advice Board 10 12-24-2008 10:22 AM
Bathroom Tiling StanJett Tile Forum/Advice Board 8 07-19-2008 11:31 AM
Tiling Bathroom jpgreen11 Tile Forum/Advice Board 3 02-24-2006 02:04 PM
