Old 03-22-2017, 05:57 AM   #31
branimal
Jake
Originally Posted by Houston Remodeler View Post
Any tempered glass can shatter (like car glass so its safer then float / window / annealed glass) when hit on the small edge.
Generally you can beat on the large flat side and nothing happens.
Its the edges you need to be careful of.
Thanks Houston.
Jake
branimal is online now   Reply With Quote
Old 03-22-2017, 07:52 PM   #32
Tempered glass doesn't like scratches or sharp impacts, other than that, it's pretty strong.
Old 03-24-2017, 11:26 AM   #33
branimal
Jake
Cut the floorboard up to 48 1/4" (expansion gap) and dry fit the new plywood. When the ply is flush to the opposing floorboard the gap is 1/4" at the north end of my cut but it's starts to grow to 3/4" at the south end of my cut.
Turns out some of the metals studs I was measuring against weren't plumb - rookie mistake to depend on a metal stud as a reference point.
What are my options at this point?
Thanks.
Jake
Old 03-24-2017, 11:59 AM   #34
Got a picture?
Old 03-24-2017, 01:44 PM   #35
Bite the bullet, get a new sheet of ply, measure carefully, cut a new piece!
At 48" or so, you'll be crossing at least 2 joist bays, which is good. You don't want any ply patches that are only bridging one bay, since that puts a huge load on the fasteners when it sags in the middle with a load. Having a joist in the middle really helps. It also significantly helps if you can offset the joints between sheets.
Old 03-26-2017, 12:48 PM   #36
branimal
Jake
So as luck would have it the section of subfloor I intended on keeping is warped and moldy so think I'll replace that section as well. So the bad cut is no longer an issue. I'll replace with a new 4' wide sheet and another strip about 6" wide.
Also my circ saw skills suck. I kept starting , stopping and restarting my cuts.
Jake
Old 03-26-2017, 12:53 PM   #37
branimal
Jake
Also do you guys suggest putting caulking between the 1/8 expansion gaps? What kind of caulk?
Jake
Old 03-26-2017, 01:04 PM   #38
1. Cut out and replace any warped subfloor.
2. When cutting out a piece, you'll want to remove the width of a least two joist bays. In other words, if your joists are 16" on center, the minimum size of plywood to cut out is 32".
3. On all plywood seams that are perpendicular to the joists, you must have a tongue and groove joint, or installing blocking to join the edges of the plywood. All seams that are parallel to the joists must fall on a joist. If you must sister a joist to correct it or to catch a plywood edge, use deck screws to secure the sister to the joist.
4. On the lower layer of plywood, you'll want to glue it to the joists with construction adhesive and secure it with deck screws every 8". On the upper layer, you'll want to use deck screws that are no longer than the thickness of both layers of plywood, using the schedule in the article that Paul referenced. If you have to use longer screws, you'll want to intentionally avoid the joists.
5. If your cut is a little bit short of the wall, you can cut the sheet back two joist bays and replace that section.
Old 03-26-2017, 01:18 PM   #39
prodjsaig
ya the tongue and groove has a built in expansion youll want the 1/8 on the end seams. but like I said its only in the event of a flood that its really that important. also the caulking not many people do it its just insurance to avoid cracked grout any sealant it just will keep your thinset out of the joints that's all
Colby
prodjsaig is offline   Reply With Quote
Old 03-26-2017, 02:26 PM   #40
branimal
Jake
3. On all plywood seams that are perpendicular to the joists, you must have a tongue and groove joint, or installing blocking to join the edges of the plywood. All seams that are parallel to the joists must fall on a joist. If you must sister a joist to correct it or to catch a plywood edge, use deck screws to secure the sister ....
Great answers. Thank you.
My joists run at a 45 degree angle to the bathroom.
How would you deal with landing on joists in this scenario?
Jake
Old 03-26-2017, 02:49 PM   #41
rmckee84
Add 2x blocking where you need it, or cut the existing so it splits on top of a joist. All that subfloor is looking pretty rough, I know its hard to tell from where I'm at.
Ryan McKee
Old 03-26-2017, 03:42 PM   #42
branimal
Jake
I'm gonna replace it all. It might be from the 1920s. It's the bottom layer of subfloor.
Jake
Old 03-26-2017, 04:04 PM   #43
branimal
Jake
In addition to 2x boxes I could but 2x studs cut at a 45 degree angle around the perimeter of the room.
Jake
Old 03-26-2017, 05:28 PM   #44
Good plan. We prefer 3 inch decking screws
Old 03-28-2017, 06:30 AM   #45
branimal
Jake
Red guard
I'm going to apply redguard to the cement board on the floor and walls of my custom shower and separate tub.
Do I need to apply redguard throughout the bathroom where there is cement board? Toilet, vanity? Walls and floors or just floors?
Do you guys recommend two layers of redguard?
Trying to figure how much I need.
Jake
HELP! The guy is tiling our bathroom now. Jimk75 Tile Forum/Advice Board 58 05-05-2014 01:12 AM
Tiling in bathroom jvandal Tile Forum/Advice Board 1 01-23-2010 09:12 AM
Tiling a Bathroom. Wow need HELP!! NotaPro Tile Forum/Advice Board 10 12-24-2008 10:22 AM
Bathroom Tiling StanJett Tile Forum/Advice Board 8 07-19-2008 11:31 AM
Tiling Bathroom jpgreen11 Tile Forum/Advice Board 3 02-24-2006 02:04 PM
