Old 03-09-2017, 08:47 AM   #1
branimal
Jake
Advice on building stand alone tiled shower...
I am building a stand alone tiled shower.
It's a dual curb Corner shower.
(I am a DIY'r- but I'm a little handy and I have a tool budget since I'm doing this myself - this project is really about amassing a war chest of tools)
I've read up on a few options:
1. building a custom shower base : subfloor-->building paper-->metal lathe-->mortar-->CPE membrane-->mortar-->metal lathe-->mortar or some variation of this.
2. Dreamline prebuilt shower base -(CANNOT TILE) seems to get good reviews, but I have read that the base can feel spongy
3. TileRedi another prebuilt shower base (CAN TILE). Reviews are not that good and some are downright bad. Also heard the base can feel spongy which can lead to breaks in the grout. The wide range of sizes and drain locations seems appealing
4. Schulter-Kerdi shower kits... (CAN TILE) Good to great reviews. Can the Schulter-Kerdi 48 x 48 be cut down to 40" x 38" or am i limited to making square cuts on it. How can the foam possibly not give a spongy feeling?
Any advice is greatly appreciated.
Jake
branimal is online now   Reply With Quote
Old 03-09-2017, 08:56 AM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I'd combine 1 and 3 and skip the foam receptor base. Surface applied membranes (like Kerdi) make most sense to me.
Peter
Old 03-09-2017, 09:21 AM   #3
branimal
Jake
What don't you like about the foam receptor base? Thx
Jake
Old 03-09-2017, 10:35 AM   #4
Carbidetooth
Hmmmmm
They're expensive and rarely would fit the space in remodel situations. Cutting to size makes edges differing heights unless equal amounts are taken all around perimeter.
Peter
Old 03-09-2017, 11:03 AM   #5
branimal
Jake
The kits costs about $500. Because I'm doing it my self I'm willing to eat that cost. I'm not sure I'm skilled enough do a custom install (option 1 above)
I can cut parallel lengths off a 39 x 39 prefabricated base to get it to fit.
The issue I'm struggling with is my shower space has a column in the corner so it turns the adjacent space into unusable space if I use the Schulter-Kerdi system. See pic upper right corner. Any suggestions on how to make that space usable? It's a 27" x 9" area.
Jake
Old 03-09-2017, 11:35 AM   #6
Carbidetooth
Hmmmmm
Where's your shower head? Valve?
I dare say you could do a mortar pan, many beginners have done it successfully.
Failing that, pehaps you just use the space in that area to recess a niche or two and keep the floor square.
Peter
Old 03-09-2017, 08:19 PM   #7
Tiger Mountain Tile Inc
tile lackey
You could put a floating bench in where the ? mark is. That way you still have floor space and shoulder space in a smaller shower. I think Schluter makes foam extensions and if they don't there's other companies that have foam shower base systems that do.
Jim Upton
DIYTileGuy
Old 03-09-2017, 09:09 PM   #8
Foam (and most other) shower bases are manufactured so that the outside edge is always level all around. Unless you cut equal amounts, one edge(s) will be lower than another. That allows the outer perimeter tiled edge to be perfectly level all around. Other than aesthetics, it has no functional imperative that dictates it must be level, but makes things harder, and some don't like the look (but, if you have a linear shower drain, the edges aren't level anyways). So, you can cut a foam pan to any size you want, but most people prefer to keep the edges level all around, so that takes a custom pan, most easily accomplished with a mudbed. Draw a level line all around, pack a rim of deckmud that is level at that line, then slope it to the drain. Deck mud is like working with wet beach sand that you pack into position. A little tricky, but not really all that hard. IT is heavy, and you don't have forever to work it, but it's not expensive and even if you make a few trial runs, it won't break the bank. Each one will get better and faster.
Old 03-09-2017, 09:46 PM   #9
branimal
Jake
The shower head and valve (knobs right?) will be on the same wall. See updated pic. I could put them on the wall with the unusable space as the pipes wrap around that way if that helps with a design you were envisioning.
Any recommended how to's on doing a mortar pan?
Thanks.
Jake
Old 03-09-2017, 09:47 PM   #10
branimal
Jake
I believe the bench needs to be inside the wet space. Meaning it has to be inside the Schulter curb. Correct me if I'm wrong.
Jake
Old 03-09-2017, 11:41 PM   #11
If you're going with a linear drain, then a foam pan would work (although more expensive), since the walls would be sloped to match the pan anyways. Note, Schluter does make a SS trim piece that can make that neater, specifically for use with their linear drain pans. Also, their linear pans come already covered with the membrane, which eliminates a step. They had talked about doing that with their center drain pans, but I've not looked carefully for awhile.
A single slope is maybe easier to do than a bowl to a center drain when doing a mudbed - the whole thing is one flat plane.
Old 03-09-2017, 11:49 PM   #12
branimal
Jake
Good point... what are the toughest parts of doing a mudbed. Sounds like the drain location choice will make the job easier for a first timer.
Jake
Old 03-10-2017, 08:44 AM   #13
The toughest part is getting over the fear of failure.
The materials are cheap, learning is priceless.
Old 03-15-2017, 05:53 PM   #14
branimal
Jake
I agree - but I have a deadline. First time diy'r
Jake
Old 03-15-2017, 06:01 PM   #15
branimal
Jake
I changed the layout a bit swapping positions of the tub and shower. The tub now sits next to the column.
It allows me to install a slightly bigger shower.
Jake
HELP! The guy is tiling our bathroom now. Jimk75 Tile Forum/Advice Board 58 05-05-2014 01:12 AM
Tiling in bathroom jvandal Tile Forum/Advice Board 1 01-23-2010 09:12 AM
Tiling a Bathroom. Wow need HELP!! NotaPro Tile Forum/Advice Board 10 12-24-2008 10:22 AM
Bathroom Tiling StanJett Tile Forum/Advice Board 8 07-19-2008 11:31 AM
Tiling Bathroom jpgreen11 Tile Forum/Advice Board 3 02-24-2006 02:04 PM
