Old 07-13-2017, 12:31 PM   #151
TileDisciple
SpectraLock Pro Premium
Originally Posted by Jon
A mini is just that, a mini kit, not a sample. And the kits come with sponges so no real need to buy one. A mini is 1/4 of a full kit. Mini kits are nice because there's no measuring. You just mix everything and grout. Epoxy grout needs to be done very quickly. I definitely wouldn't suggest anything more than a mini for a beginner, even that will be stressing you out to finish.
Thanks very much, Jon.
I'd like to use it on the shower floor, but for now I'm only testing it on the small sample board in the photo. Can I mix a small portion of the material, and save the rest?
Should the grout lines be perfectly clean of thinset before grouting?
Thanks again,
Joe
TileDisciple is offline   Reply With Quote
Old 07-13-2017, 01:18 PM   #152
If you measure the components very, very accurately, yes, you can do that.
As near perfectly as possible. A minimum of 2/3rds the way to the bottom.
Old 07-15-2017, 08:52 PM   #153
TileDisciple
SpectraLock Pro Premium Grout
Thank you, CX.
For experience sake, I decided to mix the entire contents. I put the entire contents of the mini unit, the A, B, and C, in a cooler with ice packs, one hour before I sampled it. I mixed it in my garage; it was 85 degrees. Half of the contents I put in a bucket and place the bucket in a cooler with ice packs, the other half I left out in a bucket in the garage. The half that was in the cooler was still workable even after 90 minutes. The half left in the bucket in the garage was workable one hour later.
I have three questions:
1) I'm hoping to finish my 31" by 31" shower floor with one mini container, but if I don't, I'll have to get another mini container. For those who have used several mini containers on the same project, should I be concerned about color consistency?
2) I'm planning on using the matching silicon caulk at the seems of the wall, and curb. Do I caulk where the wall and mosaic floor tile meet, and then caulk after I install the wall tile, at the seam of the mosaic floor tile?
3) The instructions indicate to use a topical sealer or grout release product on unglazed porcelain tile. I didn't do that with the sample, but I want to do it on the shower floor. What products should I consider?
Thanks very much,
Joe
Old 07-16-2017, 07:02 PM   #154
tatumjonj
Good luck with that. LOL I think I used four minis on my 39" x 42" shower floor.
Jon
Old 07-17-2017, 09:54 AM   #155
TileDisciple
Thanks Jon,
Laticrete told me it depends various factors such as the thickness of the tile, the size of the grout joints, and the size of the tile. Based on these factors, I should be able to grout nine feet of tile, which is more than what I have.
Jon, did you mix the C units together beforehand? Did you have any problem with color consistency?
Thank you,
Joe
Last edited by TileDisciple; 07-17-2017 at 10:22 AM. Reason: Forgot to ask question.
Old 07-22-2017, 11:31 AM   #156
TileDisciple
Gap between Kerdi-board wall and floor tile
Hello everyone
I'm planning on using matching silicon caulk at the changes of plain, between perpendicular walls, and between the wall tile, and the floor tile.
But what do I do with the gaps of 1/4" to 5/8", between the Kerdi-board wall, and the floor tile?
Joe
Old 07-22-2017, 11:45 AM   #157
Looks like the wall tiles will cover most of that, is that correct?
Maybe I'm wrong but it looks like you have excessive slope on your floor, if you do, that will make the joints harder to line up.
Old 07-22-2017, 06:37 PM   #158
TileDisciple
What to do with the gap between the wall and floor tile
Hello Davy,
The wall tile is 5/16" thick. In the areas where the wall tile covers the gap, do I leave the gap alone, or fill it? I had planned on adding cut tiles to the areas where there was a larger gap.
Yes, when I made the mudpan, I made the pitch much steeper than it needed to be. This made it more difficult to get the Kerdi membrane embedded, and now it's like piecing a puzzle together to get the grout joints to line up.
Thank you,
Joe
Old 07-22-2017, 08:32 PM   #159
Plus, depending on the wall tile size, you could have 1/8 of thinset, sometimes a little more. So the wall tiles may cover 7/16 or so.
Yeah, you're tiling a bowl and the deeper the bowl is, the harder it will be to keep the joints lined up. No problems with puddles in your shower.
Old 07-23-2017, 01:14 PM   #160
TileDisciple
Good point, Davy. Thank you
Best practice is to caulk every change of plane, so I should use caulk between the wall tile, and the floor tile, correct?
Since I'm planning on grouting the shower floor before installing the wall tile, it's going to be very difficult to avoid getting grout in the small space between the Kerdi-board wall, and the floor tile. Do I need to be concerned with this? Should I remove the grout that gets in that space, or not worry about it?
Or maybe it's better to install the wall tile, and grout last, doing everything at the same time?
Thank you
Joe
Old 09-09-2017, 03:47 PM   #161
TileDisciple
Shower floor done
Good evening,
Here are some photos of the shower floor. I used two mini units of SpectraLock Pro Premium Mini grout. I decided to go with #85 Almond, instead of the bright white. Although there was enough product to in one mini unit to get the job done, it got too stiff to work with, so unfortunately, I had to use a second unit, and most of it was thrown in the garbage.
On to the next phase, tiling the shower stall walls, and curb.
Thanks for your advice, and support
Joe
Old 09-10-2017, 09:49 AM   #162
Hi Joe, sorry we missed your last question. Looks like you grouted to the walls which is fine. You can caulk the joint along the bottom after you set the walls. Just shim the tiles up off the shower floor about 1/16 to 1/8.
Old 09-11-2017, 11:08 AM   #163
TileDisciple
Preparing to tile walls/curb
Hello Davy,
I actually used the matching caulk by Laticrete, Latasil, to caulk the gap between the walls and the floor tile. I love the SpectraLock Pro Premium Grout, and the Latasil caulk. The color of the caulk matches perfectly.
Thanks again,
Joe
Joe
Old 09-16-2017, 12:49 PM   #164
TileDisciple
Options to bullnose tile
Good afternoon,
The tile I chose to install on the shower wall, and curb, didn't come with a matching bullnose. I'm considering three options to bullnose the tile I purchased so I can use it on the shower wall, shower curb, and shower niche.
My first choice is to purchase a bullnose blade. I watched a couple of videos, on how to do this, and I'm leaning towards this choice. Well, I just called tech support at Rigid, and asked about using a bullnose blade on the 7" wet saw that I own, and they advised against it. So I'm left with the other choices or someone might choose to give me another option.
My second choice is to cut the tile at a 45 degree angle, and after purchasing grout colorant to match the grout that I'll use, paint the colorant over the cut portion of the tile.
My third choice is to cut the tile at a 45 degree angle, then polish the cut portion of the tile using an orbital sander with diamond grit sandpaper.
My last choice is to search for bullnose tile that will closely match the field tile.
As always, I appreciate your advice.
Thanks much,
Joe
Last edited by TileDisciple; 09-16-2017 at 01:23 PM. Reason: Rigid tech support advised against using a bullnose blade on the saw that I own.
Old 09-16-2017, 01:21 PM   #165
rmckee84
Have you looked at metal and pvc profiles?
Ryan McKee
Novice questions for a simple project Paintbb84 Tile Forum/Advice Board 9 01-22-2011 09:24 PM
First time tile project bowbndr33 Tile Forum/Advice Board 3 01-29-2008 10:33 AM
My long time project.... Meist 21 Tile Forum/Advice Board 5 12-23-2007 11:22 AM
First time project-looking for some answers lweeda Tile Forum/Advice Board 2 03-21-2007 01:59 PM
First time post/first time shower project Thomas M Tile Forum/Advice Board 6 05-21-2005 09:11 PM
