Old 09-11-2017, 12:56 AM   #121
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Originally Posted by dave.adams View Post
My drain doesn't have a step down. It was an adaptor drain for a clamping ring, and for some reason doesn't have a step down like some others I've seen.
Holy crap, you are right. I haven't seen a kerdi drain like that. Must be new? Will you post a pic of the drain assembly?
I guess i am going to look for the newest kerdi drain video.
I am neither clever nor funny
Travis
It's just a clever handle.
Old 09-11-2017, 10:01 AM   #122
Not at all new, Travis. The Schluter Kerdi adapter drain has been around for years. Nearly always better to replace an existing clamping drain with a regular Kerdi drain, but the adapter is available for situations when that is not feasible for some reason.
Old 09-13-2017, 11:45 AM   #123
dave.adams
Changed up our choice for the wall tile, any problem with using this? Ceramic semi-vitreous tile:
http://www.homedepot.com/p/205428188
Also, I've seen schluter recommends either the kerdi trowel (1/8 inch square notch) or a 1/4x3/16 v notch trowel for applying membrane. Does anybody have any strong feelings about either of these two options being better/easier to use for applying the membrane?
dave.adams is offline   Reply With Quote
Old 09-13-2017, 12:09 PM   #124
I much favor the 1/8th" square notch for installing sheet-type direct bonded waterproofing membranes, Dave. It's as close to exactly right for the application as you're likely to find.
Old 09-13-2017, 12:12 PM   #125
dave.adams
Nothing special about the kerdi one vs any other 1/8 inch square notch right?
Old 09-13-2017, 02:16 PM   #126
Shady at Best
Tyrone shoelaces
The kerdi notch trowel is special. It's fancy looking, has an ergo grip, and lacquer coated. Almost worth the $25 price tag. Oh and almost forgot, orange handle.
Go to the wood flooring isle and get the $2 disposable trowel. There should be an 1/8th x 1/8th there.
Travis
Old 09-13-2017, 03:10 PM   #127
Or attend one of their training sessions and they'll likely give you one for free! And a Ditra trowel to go with it. And maybe a backpack to carry'em in.
Old 09-13-2017, 03:58 PM   #128
dave.adams
well that answers it.
Old 09-13-2017, 05:35 PM   #129
Same link you posted before, Dave? It's a wall tile. So long as you're using it only on the walls and not in any floor application, you'll be fine.
Old 09-13-2017, 06:44 PM   #130
What about edges? Does it have a bullnose available?
Old 09-14-2017, 07:11 AM   #131
dave.adams
Yes, this is the bull nose:
http://www.homedepot.com/p/100117006
Old 09-14-2017, 07:19 AM   #132
dave.adams
Couple more questions about the layout:
(1) I'm planning to put the shower niche in stud gap that is second to the right wall, and I'm wondering if there is a standard height for a 12x20 shower niche or if it's just preference?
(2) how far out should I waterproof with the membrane and tile? The drywall ends right about the edge of the curb, but I'm wondering how far I should tile out? Just to the edge of the curb? Or if farther, do I just waterproof to the wall to line up with the outside edge of the curb and then tile out a bit more on the walls?
Old 09-14-2017, 05:25 PM   #133
dave.adams
So I just placed the membrane on the floor and then ran a couple pitchers of water on it to make sure everything was draining properly. Overall it seemed pretty good, but water seems to be pooling a bit on the side of the drain. I put the level on it as you can see, and it definitely has pitch. It's really pooling on one side of the kerdi drain, not even on the shower pan. But I leveled the drain when I set it.
Is this normal? Or will it cause problems?
Old 09-14-2017, 05:35 PM   #134
rmckee84
1. I like to run up a few courses before I put my niche in. I like to make it fall within my pattern whenever possible to avoid making it look like a chopped up mess all around it.
2.I stop just shy of where the tile ends.
3. If the drain was level when you set it, how did it get so far off now? It may not be an issue but water may struggle to find it way to the drain
Ryan McKee
Old 09-14-2017, 05:43 PM   #135
dave.adams
Well that's the level set just on one side of the drain, does that make sense? I did that to show there's slope but the water is still pooling a bit. This is the level set flat across the drain.
Doc's MB Shower Remodel DIYMAK Tile Forum/Advice Board 23 03-13-2009 05:45 PM
Shower remodel - Kerdi Shower Floor?? mirage505 Tile Forum/Advice Board 2 02-02-2007 07:58 PM
Tub/ shower remodel pitterpat Professionals' Hangout 7 11-13-2005 07:27 PM
Shower Remodel cal Tile Forum/Advice Board 3 02-09-2004 06:24 AM
Shower remodel GGL Tile Forum/Advice Board 16 02-28-2003 09:03 PM
