Old 03-18-2018, 04:13 PM   #1
Joel Cason
Combining Kerdi Board with kbrs shower pan
I am in the process of rebuilding my shower, Took it all the way to the studs. I installed a kbrs shower pan and am pleased with fit and construction. After installation, i saw an advertisement for kerdi board and marveled over the lightness, ease of cutting, waterproofness etc. Would there be any major problems anticipated if i used kerdi board with the kbrs pan instead of cement backer board?
Joel
Joel Cason is offline   Reply With Quote
Old 03-18-2018, 04:57 PM   #2
Welcome to the forum, Joel.
No, there arenít any technical incompatibilities. Of course youíre splitting up systems, so you donít have a warranty. But it sounds to me that youíre more interested in something that works rather than relying on a warranty.
You said youíre pleased with the base fit and construction. How did the install go? What material did you use to support the base?
Tonto GoldsteinÖ.. but my friends call me Bubba
Old 03-18-2018, 05:26 PM   #3
Joel Cason
Thanks for the welcome
The pan sits on 3/4" plywood on 16" centers. I had an offset drain so had a custom pan built and they nailed the dimensions. Installation was easy and went very smooth.
Joel
Old 03-18-2018, 05:35 PM   #4
Joel Cason
thinset
I forgot to say that there is a bed of modified thinset on the plywood. Used a 3/4" trowel they supplied. The drain is sealed with 100% silicone.
Joel
Old 03-20-2018, 01:15 PM   #5
Joel Cason
How long can I delay grouting.
I will not be able to finish tiling my shower before having to leave for 3 days. Is it okay to let ungrouted tile sit that long without grouting ?
Joel
Old 03-20-2018, 01:21 PM   #6
Yes. The tile won't care. The only thing that may be an issue is if dirt got in the joints prior to you grouting it. Depending on the thinset you used, having that joint open means (if it was a modified thinset), the thinset will have a chance to dry out more. It's a good idea to run a damp sponge over things prior to grouting. Not wet, damp, or use a damp brush.
Old 03-20-2018, 05:15 PM   #7
Joel Cason
Thanks Jim
Good to know. Iíll be sure and clean spaces before grouting.
Joel
Old 03-21-2018, 05:51 AM   #8
reefone
tile setter
you should clean the spacers and any thinset that needs cleaning before you leave out of town. the longer you wait the harder it will be to clean.
Jerry
tile setter 12yrs exp.
reefone is online now   Reply With Quote
Old 03-21-2018, 01:44 PM   #9
Joel Cason
Thanks Jerry
Joel
Old 03-22-2018, 02:41 AM   #10
Jim Farrell Tiler
Jim Farrell Tiler's Avatar
i have delayed grouting some tiles i laid in my rental property for about 6 months so far
Jim
no matter where you go.......there you are
Jim Farrell Tiler is offline   Reply With Quote
Old 03-22-2018, 07:44 AM   #11
Joel Cason
Thanks Jim
Joel
Old 03-26-2018, 05:37 PM   #12
Joel Cason
Kerdi board washers
I am trying to get a feel for how far to tighten the kerdi board washers down. I have looked at the videos and it appears that they tighten until the washer is below the plane of the board rather than flat against the board.I donít want to arbitrarily do this until I know the board wonít be damaged.
Joel
Old 03-26-2018, 05:49 PM   #13
Go far enough so that there isn't a lip, but you've not cracked the surface layer. The material does bend when it is compressed. When you then add the Kerdiband, it should not have a hump around the washer or screw head and your trowel won't catch on it. Try it a couple of times on a piece of scrap, and you'll see what I mean.
Old 03-26-2018, 06:24 PM   #14
Joel Cason
Thanks Jim. I do have some scrap and will practice.
Joel
Old 03-26-2018, 06:52 PM   #15
The foam is the waterproof layer, so there is little risk of pushing a washer through the foam
Kerdi Shower tray or KBRS Shower Slope infantry0414 Tile Forum/Advice Board 2 01-19-2013 09:06 PM
KBRS shower base issues Brad2001 Tile Forum/Advice Board 1 12-17-2012 06:20 PM
KBRS Shower Slope/Pan Over Old Pan nsoldon Tile Forum/Advice Board 8 02-07-2011 10:32 AM
Combining Kerdi and swanstone? Quickie Tile Forum/Advice Board 4 07-03-2009 03:40 PM
Looking for the best method, combining technologies in shower construction Kirk Grodske Professionals' Hangout 30 04-11-2006 04:45 PM
