Old 03-19-2018, 07:42 PM   #1
jlogan
Tile at exterior door, height question?
Attached is a pic of my dry install with tile and durock at exterior door threshold. I'm concerned about my height here. I've got a 1/4" left from top of threshold to top of tile.
How much growth can I expect from mud under the durock and then thinset below tile?
Jerry
jlogan is offline   Reply With Quote
Old 03-19-2018, 08:06 PM   #2
Hi, Jerry.
Boy, that’s really pushing it. If you’re using a 1/2” notched trowel for your tile, that collapses down to a little less than 3/16”. And the mortar under the cement board might be a pinch over 1/16”, depending on the exact size trowel (lots of pros may be using a 1/4” notched trowel that’s worn down to about 3/16”).
What is your subfloor? How thick of Durock were you planning? Would you consider using Ditra instead of Durock? Can the door be moved up at this point in construction?
Old 03-19-2018, 08:22 PM   #3
jlogan
I've got osb subfloor, 1/4" durock and was planning on using a 1/4" x 1/4" trowel. Negative on the door being moved up.
Jerry
Old 03-19-2018, 08:24 PM   #4
jlogan
Oh and have no idea about Ditra. So hadn't considered it.
Jerry
Old 03-19-2018, 08:48 PM   #5
This would save you 1/8".
Old 03-19-2018, 08:58 PM   #6
jlogan
Yea, I think I'm already sold on the idea. Do I still us unmodified under the Ditra? I've got two bags that cover 75sq ft./bag. on a 132 sqft. kitchen floor.
This for the thinset under tile
http://https://www.homedepot.com/p/Custom-Building-Products-VersaBond-LFT-50-lb-Gray-Fortified-Medium-Bed-Mortar-VBLFTMG50/205789819
This for under Ditra.
https://www.lowes.com/pd/MAPEI-Large...um-Bed/3743785
Jerry
Old 03-19-2018, 10:08 PM   #7
Depends on what you're installing Ditra over. Assuming this is plywood, the regular Versabond will work. You don't really need a large format mortar under Ditra.
Old 03-20-2018, 05:56 AM   #8
reefone
tile setter
if your installing ditra over plywood you do not want to use the versabond lft. it doesn't inbed the fleece enough. ive tried. regular versabond does a way better job. so id take the lft back and get the regular.
Jerry
tile setter 12yrs exp.
reefone is offline   Reply With Quote
Old 03-20-2018, 01:00 PM   #9
jlogan
I'm installing over OSB. Will the regular work for that too?
Jerry
Old 03-20-2018, 01:10 PM   #10
Yes it will.
Urgent question: door height for semi frameless asmad Tile Forum/Advice Board 22 12-10-2013 07:30 PM
Exterior French Door Threshold question whaddaya know Joe Tile Forum/Advice Board 3 06-26-2011 01:59 PM
Tile against exterior door threshold PSULion92 Tile Forum/Advice Board 5 10-17-2007 12:55 PM
Exterior tile up against sliding glass door itsme Tile Forum/Advice Board 2 07-06-2007 05:24 PM
Question: Can exterior tile be installed at a total height of about 0.5" laurallee Tile Forum/Advice Board 7 06-15-2006 12:11 PM
