Old 09-15-2016, 09:22 PM   #1
dzaporo
Type S vs Type N mortar for mudset tile job
Anyone know if better to use Type N or Type S premixed mortar mix such as Quikrete to install 24x24 porcelain tile.... thank you!
Den
dzaporo is offline   Reply With Quote
Old 09-16-2016, 06:21 AM   #2
CountryBumkin
CountryBumkin's Avatar
Send a message via ICQ to CountryBumkin
Where are you installing the tile?
See https://www.tcnatile.com/faqs/64-thinset-mortar.html
CountryBumkin is offline   Reply With Quote
Old 09-16-2016, 11:03 AM   #3
Cain
Cain
No neither are acceptable to set tile with.
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Old 09-16-2016, 04:05 PM   #4
The Kid
The Kid's Avatar
Thinset,drypack,thinset will be your best bet for mud-set method. The mortars which you described tend to shrink a great deal when used really thick.
Why do you want to mud-set the porcelain? ??
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Old 09-19-2016, 10:03 AM   #5
dzaporo
Using quikrete mortar mix sandwiched between thinset (about 1" of mud) to install 24X24 porcelain with 1/16 grout over concrete slab covered with Whispermat sound proofing in highrise condo in Miami. Mudset installs are typical in this area in highrises as the slabs are not very straight.
Always thought that regular premixed mortar works fine but read that type s mortar tends to shrink more than type n. Personally have not noticed any difference in the installs that I have done. Always thought that premixed mortar is nothing more than sand with cement. Same as typical mud that would be mixed onsite.
Den
Type S Mortar use? HandymanStan Tile Forum/Advice Board 4 07-24-2011 07:46 PM
What type of mortar bed for pan? Isaac Tile Forum/Advice Board 6 02-02-2009 03:58 PM
Type of Mortar TheIcon Tile Forum/Advice Board 18 02-15-2008 12:30 PM
What is your vote for best type of grout in kerdi shower and best type of caulk dcousins Tile Forum/Advice Board 2 12-14-2006 03:26 PM
Mortar Type renegadecj Tile Forum/Advice Board 3 11-19-2004 08:15 AM
