Old 03-15-2012, 06:48 AM   #1
ds_turner
Pre-slope question for rectangular shower area
You folks really know your stuff. I have a question re: preslopes. I have a rectangular shower area. The drain is not centered. The run from the drain to the furthest wall is 6'. The other 3 walls are roughly 2' from the drain. I get that the slope from the drain to the furthest wall should rise 1.5". My question is how much should it rise from the drain to the near walls? 0.5" would give me the 1/4" per foot I need, and seems to be what I would get if I use some of the tools from Mark E (goof proof shower), but then it would not be a level line along the wall and I'm struggling to see how the wall tiles would look against a floor bed that slopes.
I'm guessing that I should drop 1.5" over the shorter three 2' sides (overkill re: slope) and then the same 1.5" over the 6' run (to code), which will then give me a level outer edge of my preslope (and ultimately the tile bed), but is 1.5" over 2' too much??
Hope that all makes sense.
ds_turner is offline   Reply With Quote
Old 03-15-2012, 07:09 AM   #2
Hi Dave, Welcome aboard.
Keep the perimeter of the floor level all the way around. The longest run is 1/4 in. per foot, or 1-1/2 inches in your case (you are correct).
The three other runs will be steep, but not too steep. You won't have to figure those slopes; just go from the top of the drain to the level perimeter. Most of us will create a mud "screed" around the perimeter first.
A very experienced setter might be able to cut the long slope down a bit -- maybe to an inch, but if everything is not perfect you'll have "bird baths" in that run. I would stick to 1-1/2 in.
Never form the perimeter out of level. It's a mess, and it looks terrible.
Old 03-15-2012, 10:01 AM   #3
Welcome, Dave.
Keep in mind also that the 1/4" per foot slope is a minimum and you need your floor to slope everywhere, including that far corner, from which you should be measuring your maximum horizontal distance from the drain.
Moving the drain to the center of the shower floor is always a good idea.
Question: Basement Shower, Max Pre-Slope Thickness? creepe Tile Forum/Advice Board 4 08-08-2006 05:52 AM
Shower curb & pre-slope question? latasaurus Professionals' Hangout 1 07-12-2006 09:58 AM
Question about pre-slope tilerite Professionals' Hangout 19 01-22-2005 10:31 PM
pre-slope question hap Tile Forum/Advice Board 12 04-22-2004 07:46 PM
Shower Pan - Curb Question & no pre-slope TryinHard Tile Forum/Advice Board 8 01-05-2003 06:55 PM
