Old 02-22-2018, 04:55 PM   #1
rtsisu
12x24 layout
What is the recommended layout for large format tile in a business restroom? The same 12x24 tile is being used for the floor and the wall wainscot ( 48 in ). The room size is 6 ft by 8 ft with the door on a 8 ft wall and the vanity/stool against the 6 ft wall.
roger
rtsisu is offline   Reply With Quote
Old 02-22-2018, 05:52 PM   #2
rmckee84
Most time an offset of no more than 33% if staggering or just straight lay. If the tile is very flat you may be able to do a 50% offset.
Ryan McKee
Old 02-22-2018, 06:10 PM   #3
rtsisu
12x24 layout
Would you use different patterns for the walls and floor such as straight lay on floor and 33 percent on walls?
roger
Old 02-22-2018, 06:33 PM   #4
EASA
EASA's Avatar
Installer's choice?
33% offest on the floors, center and balanced grid on the walls. I always push for that recommendation for ease of layout and grout joint alignment.
I have those AT&T restroom photos here somewhere...
Erin
www.jandrtile.com
NTCA 5 Star Contractor
Dept. Of Labor Approved Apprenticeship
CTEF Texas
EASA is offline   Reply With Quote
Old 02-22-2018, 08:50 PM   #5
Yeah, I would know the pattern before I start the job. Someone in charge will need to tell me what pattern to install. And the grout color, etc.
Old 02-23-2018, 05:29 AM   #6
rtsisu
Question 12 x 24 layout
Erin,
Thank you for the response. What do you mean by "center and balanced grid"?
roger
Old 02-23-2018, 11:23 AM   #7
EASA
EASA's Avatar
Either joint on center, or tile on center, with grout joints aligning with no less than 1/2 of the tile as a cut (walls) and 33% on the floors.
Erin
www.jandrtile.com
CTEF Texas
Old 02-23-2018, 09:27 PM   #8
Tiger Mountain Tile Inc
tile lackey
This is fine. Sometimes this can free you from lining up the wall tile with the floor tile pattern. Although, if it's the same tile, then it will be difficult to not have parts of the floor carry over to the walls.
This is where going with two completely different sizes can be of assistance.
Jim Upton
DIYTileGuy
12x24 tile layout prancer Tile Forum/Advice Board 45 04-25-2017 08:35 PM
12x24" tile floor layout in small bathroom shark_bait Tile Forum/Advice Board 6 03-13-2017 12:27 AM
Multi room 12X24 tile layout shaliddle Tile Forum/Advice Board 15 05-26-2015 10:22 PM
12x24 floor layout advice spwc Tile Forum/Advice Board 11 11-03-2014 02:45 PM
12x24 ballardtile Professionals' Hangout 13 04-28-2010 09:04 PM
