Old 04-05-2009, 10:45 AM   #1
Court
1st time tiler working with colorbody textured porcelain
What can I say but that this product has the appearance that I want. Not glazed, but colorbody porcelain with slate like texture. Breaking strength > 335 Lbs, MOH's hardness = 9.0. Will I be able to score/snap cut this tile with a Rubi TS-40 plus with the proper cutting wheel? If so, what is the best cutting wheel? On the plus side this tile is only 1/4" thick.
Court is offline   Reply With Quote
Old 04-05-2009, 10:48 AM   #2
who makes it ?
some porcelain is very hard and a hand cutter will score it but it will break and whip where it wants.
most likely your going to need a wet saw.
does it look like this ?
some Marazzi are tough to cut.
Old 04-05-2009, 10:52 AM   #3
Court
American Olean Highland Ridge series 12 X 12
Old 04-05-2009, 10:54 AM   #4
1/4" you should be fine to cut with a hand cutter.
Tile Thickness: 1/4"
Old 04-05-2009, 10:55 AM   #5
Court
Forgot to add, but yes it has an appearance similar to that tile in your picture.
Old 04-05-2009, 10:58 AM   #6
I looked, it's nice stuff.
mostly all American Olean's stuff is good.
http://americanolean.com/series.cfm?series=112
Old 04-05-2009, 11:22 AM   #7
Court
How about the cutting wheel? I know Rubi makes a porcelain specific cutting wheel but I have seen someone suggest the "tiny" wheel for textured porcelain. I do not know if they are the same wheel.
1st time tiler, need to fix a runout mistake mowshweettea Tile Forum/Advice Board 5 01-18-2009 10:46 PM
1st time reader 1st time poster ?'s about building a custom shower... itsnatestate Tile Forum/Advice Board 8 04-17-2007 08:00 PM
dry grout...1st time user 1st time post wickm Tile Forum/Advice Board 2 04-17-2007 06:19 PM
1st time tiler with travertine needs help! cbold68 Tile Forum/Advice Board 18 03-20-2007 11:33 AM
1st Time Tiler - Important questions... smarsh Tile Forum/Advice Board 4 10-13-2005 05:44 PM
