Old 12-01-2011, 04:04 PM   #1
passmal
Polished porcelain problem
We recently had a contractor install Polished porcelain tiles in our kitchen. They are very slippery, and impervious to non-slip sealers. Does anyone have any recommendations or suggestions on applications I can utilize to make the tiles non-slip? Thanks in advance...
ali
passmal is offline   Reply With Quote
Old 12-01-2011, 04:14 PM   #2
johntrent
Ali - here is a product I have heard good things about but never tried it myself.
http://www.invisatread.com/
John
johntrent is offline   Reply With Quote
Old 12-01-2011, 04:14 PM   #3
java
Hugging Trees Oct. 1st
java's Avatar
Kool-aide.
Probably lemon or lime flavor so it won't be to noticeable.
Works at my house anyway.
Jason
java is offline   Reply With Quote
Old 12-02-2011, 10:26 AM   #4
passmal
Thanks, John.
ali
Old 12-02-2011, 04:01 PM   #5
CanyonTile
Invisitread is a great product. Your local Emser tile should carry it.
SlipGuard is also decent : http://slipguardsystems.com/
Gabe
We Got You Covered
www.canyontileandstone.com
CanyonTile is offline   Reply With Quote
Old 12-02-2011, 04:10 PM   #6
tiletime56
Shaun Haley Tile
tiletime56's Avatar
Send a message via Skype™ to tiletime56
trusty step... another good product
Shaun
https://www.facebook.com/lists/22363...e/172655561618
Luv fat mud!
tiletime56 is offline   Reply With Quote
Old 12-19-2011, 11:28 AM   #7
passmal
Thank you for all of the great insight.
I tried, Invisitread without success. I left the product on for 24 hours and it didn't dry :/ I'm assuming the non-pourous/polished finish is the problem...
still searching for a solution...
ali
Old 12-19-2011, 01:34 PM   #8
tiletime56
Shaun Haley Tile
tiletime56's Avatar
ali did you follow the instruction to the tee, wondering cause I am about to purchase some for a project
Shaun
Luv fat mud!
Old 12-19-2011, 03:38 PM   #9
passmal
yes, to the tee. the tiles have a polished surfaced that seems to be impregnable to the solution.
ali
Old 12-19-2011, 05:26 PM   #10
Vwcrackerjack
Itile345
Vwcrackerjack's Avatar
Wear the socks with little rubber dots on bottom :-)
Jamey
Vwcrackerjack is offline   Reply With Quote
Old 12-19-2011, 08:19 PM   #11
doitright
doitright's Avatar
Hi Ali
I had a client with very slippery polished granite paver's from the driveway to the front door. I did some TESTing with a restoration product that contained some hydrofluoric acid. It did the trick without badly discoloring the stone (as it was black).
If you're interested, I'll dig up the product. I know it was made by Prosoco. I don't suggest using anything without TESTing on a extra piece first.
John Koessler
Old 12-23-2011, 11:31 AM   #12
passmal
Hi John, Yes I would appreciate that! Thanks in advance...
ali
Sealing polished porcelain MrSmoothy Tile Forum/Advice Board 14 01-17-2008 02:49 PM
vinegar and polished porcelain lyndaz Cleaning, Restoration and Sealing 1 02-01-2007 08:00 PM
Polished Porcelain John K Professionals' Hangout 12 11-08-2005 08:04 AM
Polished Porcelain Nazmi Gabriel Cleaning, Restoration and Sealing 3 08-19-2004 07:15 AM
polished porcelain Gordo Tile Forum/Advice Board 1 07-21-2004 06:40 AM
