Old 04-17-2009, 04:58 PM   #1
pokskid
sister joists?
I have a question regarding sistering joists. I am planning to install porcelin tile in my master bath, which sits above our dining room. Using the deflector the floor barely meets the minimuns. 11' span 16" OC joists are in good shape 3/4" ply. Being my fathers son I want to make sure that the floor will not fail. So I decided to tear out the ceiling in the dining room and either sister the joist or add new ones 8" OC. Which do you recommend.
Darren
pokskid is offline   Reply With Quote
Old 04-17-2009, 06:35 PM   #2
GabeS
Barely meeting the minimum is still meeting it right. Why go through all that craziness?
Not sure which method carries a higher yield, but they are both effective. Gluing and scewing a 2x4 to the bottom of the joists will double the strength also.
Gabe
GabeS is offline   Reply With Quote
Old 04-17-2009, 07:34 PM   #3
pokskid
Yeah I know it is a little crazy. I was planning on doing some work in the dining room anyways(new lighting). So this will just move that project up a little bit. I know my wife will appreciate that since she wanted that done first. So I will kill two birds with one stone here.
Thanks for the assistance,
Darren
Old 04-17-2009, 07:56 PM   #4
GabeS
I played around with the numbers in deflecto and it seemed like doubling the joists had a stronger effect than decreasing the spacing between them. You could try for yourself in deflecto. It wouldn't let me type in less than 10" on center for spacing. For thickness, just put three inches (because that's what it will be if you double).
Gabe
Old 04-17-2009, 08:15 PM   #5
pokskid
I think I will go ahead and sister them. I can't think of a better way to spend my Sat. now that our weather up here in MN has finally taken a turn for the better.
Have a great weekend,
Darren
How to Properly Sister Joists? advertguy2 Tile Forum/Advice Board 7 03-03-2009 09:06 AM
To sister or not to sister joists D-Train Tile Forum/Advice Board 9 12-17-2008 09:41 AM
sister boarding to cupped joists mattbusche Tile Forum/Advice Board 5 08-14-2008 10:25 AM
2 piece sister joists wudtogo Tile Forum/Advice Board 14 01-25-2006 08:44 AM
Sistering DF solid joists with I-Joists: bad idea? MartinGFoster Tile Forum/Advice Board 8 12-05-2003 04:33 PM
