Tile Your World
Experts from around the world have gathered at the TYW Forums to give great free advice to DIY'ers on ceramic tile and stone installation.
Tile Your World Book by John Bridge
John Bridge's new book, Tile Your World, is available at the TYW online store. Get your autographed copy now!
View Full Version : Proper way to install backer board
You are viewing a text version of the John Bridge / Tile Your World Advice Forum. You are more than welcome to use these pages, but your experience will be more satisfying if you use the real Tile Advice Forum. There you can ask experts from around the world any question related to tile and stone installation, or any other construction related question, free of charge! Our purpose is to provide the very best Tile and Stone Installation and Maintenance advice on the internet. We love to help "Do it yourselfers" through projects from start to finish.
Kurt M. - Fri Jul 23 10:28:17 2004
Good morning. I just found this forum and I am excited. I hope that some of my question can be answered her. I am fixing to redo our entrance hall. I plan on putting a hardwood floor border (about 10 inches) around the outlines of the hall. Then I plan on laying marble to fill in the remaining space. Of course I will be laying the marble first and then the hardwood border. I am pretty handy with many aspects of DYI, but never worked with marble or tile. I spent tons of hours researching and learning as much as I can before I start my little project. Of course, my wife wants to know why it isn’t done yet. Our subfloor, 5/8 plywood, is in pretty good shape. I plan on laying down a cement board where the marble goes. I have read many references to hardi boards to use instead of cement board. What is a better material to use, cement board or hardi board? I am also not sure regarding the spacing between the tiles? I was told by some not to leave any space between the tiles and others told me to leave 1/8 in. When I visited a model home I saw space between tiles of ¼ in. What is the recommendation? Also, if I butt the tiles together there wouldn’t be any space for grout lines and I would think grout actually makes it more compact and rigid. Am I wrong? Last question for now. What is the recommended thinset thickness? Seems that ¼ in is common, but is this true for marble as well? Once dry, will it remain ¼ thick? Thanks, this is truly a great forum and I think it’s great that many of you professional pass on your experience and tips
bbcamp - Fri Jul 23 12:55:54 2004
Welcome to the forum, Kurt. 5/8" subfloor is not thick enough for marble. You will need 1-1/4" (not counting your backerboard). We will also need to look at your floor joists to see if they are up to a marble installation. Marble, like all natural stones, needs a floor that is twice as strong as a ceramic tile floor, and that's pretty strong in itself! As far as the backerboards go, use whichever one is available, they're all about the same. I'd rethink the order of installation. You will be nailing down the hardwood which shakes the floor. Tiles don't like that. You can finish the hardwood, then protect it with rosin paper and painter's tape during tile installation. Don't ever butt tile together, leave a grout gap. For marble, it can be small, 1/16" or so. In any case you want the grout line less than 1/8" so you can use unsanded grout. Sanded grout will scratch the marble tiles, both during installation, and during regular cleaning and maintenance. Thinset is thin. Probably 1/8" to 3/32". However, if your tiles are large, then you will be using a medium set mortar, so the thickness may be greater. The notch size is not the final thickness, the thinset smushes down when you set the tile, so there are no voids under the tile. It doesn't shrink noticeable when it cures. So, do you need to tell the wife that you'll need more research time? :D Bob
Kurt M. - Fri Jul 23 13:47:26 2004
Thanks Bob, for the reply. I was affraid that the subfloor would not be strong/thick enough to support the marble. The actual area that would see marble is only 12 x 5 ft. The rest would be hardwood flooring. Still need the 1-1/4 subfloor? I hate to see a great difference in floor height between the hall and other rooms. BTW, thanks for the reco to install the wood floor first. I can see the marble tiles shaking loose when I air nail the wood.
jadnashua - Fri Jul 23 15:12:50 2004
I read in one sequence that if you cut out the subflooring, you could build it up between the joists, with additional flooring on top of the joists. This may help you reach the desired thickness and keep the entire height similar to the other rooms. Someone else may give you the details of how this is done.
Kurt M. - Wed Jul 28 10:53:23 2004
In preparation to install marble floor I need to lay down ½ in backer board (i.e. Hardi or Durarock) and was wondering what the proper way of preparing the subfloor is? I read somewhere to staple polyethylene plastic on top of the subfloor and the backer board on top. Is the backer board only held in place by screws? What is the proper spacing for the screws (3-4 in)? I would really appreciate if someone could tell me the proper way/method. Thanks Kurt
Mike2 - Wed Jul 28 11:15:46 2004
Hi Kurt. Glad to have you with us. :) Your homework assignment for the day will be to visit each one of these two links containing detailed instructions on how to install either product. Hardibacker Durock Then come right back here and ask any clarifying questions you may have :nod: P.S. Are you sure your floor is strong enough to adequately support a marble tiled surface? Our engineer bbcamp will be glad to help you with that question but first he will need some more information like: What size are your joists, how far apart are they spaced, and what is the longest unsupported span? Additionally, a description of your sub-floor would be most helpful.
Kurt M. - Wed Jul 28 14:21:54 2004
Thanks for the directions Mike. In a previous post I already received much of the info I need. I plan on redoing our entrance hall. Basically laying down a perimeter of about 1 ft of hardwood flooring all around and filling the middle with marble. The hall is about 13ft x 5.5 ft. Not really a large space. Joists are 8in and spaced 16in. One thing that does not help is that the joists go in the same directions as the hall space adding to the flexing of the subfloor. The subfloor is 3/4in and in very good condition. I plan on using ½ in backer board to come to the recommended thickness of 1 ¼ in. before putting the marble down. I think your link to the Hardibacker installation instructions answered my questions.
cx - Wed Jul 28 15:21:17 2004
OK, Kurt, you gotta come clean here. :shades: I merged your former thread in here, just stay with this same thread until this project is complete or we'll not know what you've been told and have told us. Now, if you'll look back a few posts you'll see that Injineer Bob done already tole you the following: 5/8" subfloor is not thick enough for marble. You will need 1-1/4" (not counting your backerboard). We will also need to look at your floor joists to see if they are up to a marble installation. Marble, like all natural stones, needs a floor that is twice as strong as a ceramic tile floor, and that's pretty strong in itself! So, first of all, which do you have, 5/8ths or 3/4 inch subflooring? Second, you gotta be specific about the size of your joists and tell us the actual unsupported span of the joists. If, in fact, you have only 2x8 joists spanning 13 feet, we're not gonna recommend you install any kind of tile until you correct that situation, and certainly not natural stone. Out with the information or my next call is to the Tile Ranger and I don't make that threat lightly. :eek: No sense spending the time and money on an installation that's not likely to survive, eh? :)
bbcamp - Wed Jul 28 15:27:34 2004
Kurt, your joists are undersized for marble or ceramic tiles. If there were some way to reduce the span of the joists to something less than 8 feet, then you could make a go of it. Also, you don't count the backerboard for subfloor thickness. You can, however, add plywood under the existing subfloor. You can glue and screw sections of plywood (face grain perpendicular to the joists) to the bottom side of the subfloor, then add cleats to the sides of the joists to support the ends of the new pieces.
kurtwm - Thu Jul 29 18:59:56 2004
I measured and re-measured. The joists are 10in and not 8 as I indicated previously. I also checked from the basement and never even realized that the floor is supported by a wall, as well as an I-beam about 7ft down the hall-length of 13 ft. The wall was put in by me and uses 6in studs (leads to a wine cellar). So, while perhaps not designed to hold a load, it certainly helps as well. I jumped up and down on the floor and there is absolutely no bounce whatsoever. Please tell me to go ahead with my plans. I dry fitted all pieces last night, including the backerboard, the marble, plywood to raise the floor for the hardwood flooring around the tile and it looks fantastics. Having to raise the floor doesn't look very nice where it transitions into other rooms, but since I will be laying down hardwood flooring there also, the uneven transition will go away later.
cx - Thu Jul 29 19:14:13 2004
Joist support sounds fine, Kurt. :) I'm a little confused by some of this: I dry fitted all pieces last night, including the backerboard, the marble, plywood to raise the floor for the hardwood flooring around the tile and it looks fantastics. Having to raise the floor doesn't look very nice where it transitions into other rooms, but since I will be laying down hardwood flooring there also, the uneven transition will go away later. You do understand that you must add another layer of plywood (you still haven't clarified whether you have 5/8 or 3/4 now) over the entire area to be tiled? And you further understand that it's not necessary to use 1/2 inch CBU if height is a concern? Quarter inch is fine, and Ditra would save you an additional 1/8 if you use it in lieu of CBU. And you further understand that I actually have the Tile Ranger's number in my speed dial? :D
kurtwm - Thu Jul 29 21:31:01 2004
Let's see if I can be a little more specific. The floor is 3/4 plywood. THe funny stuff made from a gazillion little pieces. I purchased 1/2 backerboard to raise/support the floor to, what I understood, 1 1/4 in thickness. I m now confused however, why would I need another layer of plywood?
cx - Thu Jul 29 22:15:57 2004
OK. That's not plywood, Kurt, that's OSB, Oriented Strand Board. Store that in your memory bank, it'll come up again. On top of that subfloor you must add a minimum of 1/2 inch plywood (not OSB) in a grade of C or better, like AC or BC or CC plugged (which you ain't likely to find. You can add thicker ply, but not thinner. This will give you the recommended inch and a quarter subfloor, which does not count the CBU. CBU adds nothing in the way of structure to the floor, it's only there to provide a good tiling substrate. It can be 1/4 inch thick, or you can replace it with Ditra which is only 1/8th inch thick. What's your pleasure?
kurtwm - Thu Jul 29 22:25:01 2004
Makes a ton of sense what you are saying CX. I will exchange my 1/2 board and go with your recommendation. Adding another 1/2 plywood and using Ditra. I like to do it right the first time. You can now dump the Tile Ranger's number.
cx - Thu Jul 29 22:45:12 2004
Ooooh, no, no, no, never know when we'll need to call the ol' Ranger. Get some pretty stubborn people hereabouts sometimes. ;)
kurtwm - Sun Aug 1 14:23:49 2004
I'm happy. Followed all instructions given here and I am now ready to grout. Seems pretty straight forward, go diagonally across the seems. But, is there anything special I should look out for? For example, should the grout be flush with the marble? How to wipe off excess grout? Can I just use a wet finger to go over the grout line to get the desired depth? Any hints are appreciated. Kurt
kurtwm - Sun Aug 1 22:31:51 2004
I could have sworn I posted my question earlier today and the threat moved to the front again, but my post from this morning is not here. Anyway, I am very happy that I am finished laying the marble following the suggestions given in this thread, I am now ready to put down the grout. Seems simple, just go diagonally across the tile. But, I do have some questions. Should the grout be level with the marble? Can I just use a wet finger to go over the grout line to get an even depth or is there a better method? THe spacing between the marbles is 1/16 in. Is there anything else I should do or consider before getting started? Thanks Kurt.
cx - Sun Aug 1 22:43:02 2004
Well, Kurt, I don't know what to tell you, but on my screen the post immediately above your last post is another post from what appears to be you with the same question. I don't know what things look like if a fella's not registered, but get yourself registered and you may find it easier to keep up with yourownself. :D
Kurt M. - Mon Aug 2 07:42:37 2004
Sorry, all this high-tech stuff. I didn't notice the little page x of x on the bottom and didn't go to the second page. THat's why I didn't see my post. My mistake and sorry for my confusion. So, are there answers to my questions? Kurt
John Bridge - Mon Aug 2 19:19:10 2004
Kurt, Use a sponge, will wrung, to wash the excess grout off. Move it across the joints and not along them. Do this a couple times. Make sure you leave no residue on the tiles. I'm going to repeat that. Make sure you leave no residue on the tiles. :)
kurtwm - Tue Aug 3 22:25:08 2004
Thanks all for helping so far. This afternoon I put the grout down and it came out great with very little of a mess actually. Now, Really have a problem however. The top of the marble is 6/8 from the subfloor. I am ready to place the hardwood around the marble. The hardwood is 3.8 thick. That leaves another 3/8 I have to build the floor up to get the hardwood floor even with the marble. I looked all over, but run out of ideas. I considered putting roofing paper and 1/4 in plywood on top, but I'm afraid it's too much roofing paper. I considered placing cork under the plywood, but don't know what it would do in the long run, Any ideas what I can do? Keep in mind that there will be only 12 in of hardwood all around, the rest is marble. I doubt that there will ever be a heavy load resting on the hardwood because of the width. Btw, I didn't take the advice and put down the hardwood first. I was afraid I wouldn't be accurate enough and end up with a sloppy job. Since I can't air nail the hardwood floor (not enough space for an air nailer, I will have to glue it down.
Mike2 - Tue Aug 3 22:34:10 2004
3/8" ply??
kurtwm - Tue Aug 3 22:41:45 2004
unfortunately I can't find 3/8 ply at Lowe's or HD.
cx - Tue Aug 3 22:53:34 2004
The 3/8ths ply is the most reasonable approach, Kurt. It's not rare. If Homer doesn't have some, it's almost certainly because he's run out. Somebody in your town will sell you some. And it'll be just enough undersized to allow for some glue on both sides. Aughta be a near perfect fit. :)
Peggy Donahue - Tue Aug 3 23:27:56 2004
Open your phone book and find a lumber yard....yes they still exist.
tileguytodd - Wed Aug 4 08:02:05 2004
Another option, 1/4" Plywood and a Pad.they sell padding for underneath laminates that may well make up the differance.sems to me its about 3/32 or an 1/8".alot depends on how you are attaching the wood or if it will be a free floating install.free floating would likely require a T Moulding at outside edge and you could slip it under the marble leaving a 1/4" for expansion etc. Otherwise, a couple layers of 30# felt under your 1/4" Plywood would likely be best :)
cx - Wed Aug 4 09:19:12 2004
I'm thinking with only a ten inch wide border of wood floor, he shouldn't be trying to float it, Todd. I suppose you could, though.
Search our site!
Google
  Web johnbridge.com
Message index
