View Full Version : Tile Forum/Advice Board
- Welcome
- newbie
- Waterproof foot tub
- Grout stuff?
- Fancy Stuff
- pictures?
- Leaky Shower
- Swanstone anyone?
- Thinset or Slurry
- Saltillo on elevated - exposed deck
- roll-in shower?
- Hey There!
- Install shower before tiling??
- hello
- Grab Bar
- Mud-bed! Keeping me awake!
- wire mesh
- Questions on tiling
- Making Slibowitz (licquor)
- Ecomonics of mud vs. cement backer?
- Sealed Granite?
- Shower Pan Re-Do
- Covering brick fireplace
- tile shelf
- tile/wood transition
- tile repair
- cottage cheese ceilings
- tile on concrete with movement joint
- Meet a Mud Man
- saltillo Tile
- Newbie homeowner
- Tile shower enclosure
- Threads being moved
- Slab floor prep, after vinyl removal
- Tile Layout on Diagonal
- Grout sealer?
- Vinyl Tile Removal - HELP !!!!!
- trip to stone fabrication class
- The wife really wants marble tile, but . . .
- Marble is cracking
- Bleached Grout
- Another tile/wood transition question
- Wood left in slab.
- Tiling bathroom counter
- Wood Left in Slab Part 2
- Steam Shower
- Shoul we pull up vinyl linoleumn flooring?
- Pulling up vinyl linoleumn?
- Crack in Slab
- quarry on a porch
- Any thoughts on Semco for use on cracks in slab?
- Tile around bathtub and in shower
- Small hexagon bathroom tiles
- Preparing floor for ceramic tile
- Tile question for basement floor
- tile over formica
- Shower Caulk
- Prefab Shower Pan
- Grouting large jobs?
- Is there a market out there for plastic wall tiles?
- Tile on a screen deck porch?
- Ready to grout
- Tile installation
- quary tile questions
- Shower Re-Do As Meditation
- cracked tiles and expoxy grout
- grout problem
- CRACK ISOLATION
- Family fun night
- Tile over a concreat slab
- Installing a shower
- Thank you already!
- Tub -> Shower stall conversion
- Thin Set on a riser.
- Where do you buy tile?
- Removing Tile - Help!
- shower pan
- Porcelain Tile Shower
- Concrete prep.
- No Bull Nose Tiles!
- TO kalford
- Grout lines and layout.
- Slab prep and questions
- cleoantony
- Painting over ceramic tiles
- Bathroom Remodel/Americast Tub
- Sunken Living NO BULL NOSE
- CONSUMER FLOORING GUIDE: INTERNET RESOURCES
- We Love Our Insurance Adjustor
- Grout Sealant???
- Not a tile question. Carport.
- So far so Good ? + a Few More Questions
- Drilling into floor tiles.
- RADIANT HEAT
- Scratched Marble Tiles
- Shower head
- Michael Byrne's Article
- Closet flange height for tile
- Cracking grout
- You guys are fantastic!
- GROUT LINE THICKNESS
- Removing grout from mosaic tile.
- Metal Shower Stall
- installing shampoo niche in shower
- Uneven backerboard
- Irregular Border
- Question on Bonsal niches
- marble floor
- Shower HELP!
- FOLLOW UP ON BACKER BOARD
- What size tile?
- epoxy grout
- Cutback revisited
- Another thing
- Painting Already Installed Tiles
- Answers and questions
- Grout vs Versa Bond (OOPS) ?
- Dusting the grout
- RESPONSE TO JOHN'S LATEST
- Tile / Carpet Transitions
- Lining window jambs with CBU
- alternative to tile showers
- Grout Manufactors
- "Better-Bench" shower benches
- Tile on concrete
- Difficulty of different Square Patterns
- Another Novice
- New wall tile over old dried mortar
- Installation of 18x18
- CBU vs Greenboard in bathrooms
- Remove and Reuse
- Bud is in charge
- CBU Woes
- Help please
- Help with a Shower Base
- T-shaped tile spacers
- ceramic over laminate
- installing slate tile
- Shower Confusion
- Screw Heads and Hardibacker
- Saltillo Tile?
- How far down should CBU go in a shower?
- Librarian Tilesetters?
- 2 different thin sets?
- hello again
- Edge treatment for wall tile
- Bathroom/kitchen tile/stone installation
- tile and radiant floor heat
- GROUT
- Substitute for plywood as an underlayment?
- slope on shower curb
- Starting off right...
- Trying to cut round cornor
- Asbestos Linoleum
- Tile Backsplash and Laminate
- I'm a Tilesetter!
- Sealing Tile
- Cutting Porcelain Tile
- Sloped Floor and Curb
- preparing concrete for tile
- Grout scratched my tile,,, Now What???
- Flooring options
- The Big One
- When to seal grout
- hairline cracks in grout
- porcelin tile
- Affordable alternatives for countertop material?
- caulk or grout?
- Help, quick!
- tile on a cracked slab
- removing old shower drain
- Installing glass block window in shower
- ceramic floor tile layout
- grout
- Thinset for Dal-Tile Porcelain?
- frosted glass tile
- Building Custom Bathtub & Shower
- Waterproofing membrane
- remodeling tile over plywood help!!!!
- Help...Need Quick Turnaround Time
- ceramic tile gone bad
- removing cracked tile
- Laying Slate
- Starting Basement Complete New Shower Addition.
- Will it last?
- Tile adhesive or thinset?
- Grout, Am I doing it wrong? HELP ! ! !
- sound proof pergo under tile???
- porcelain tile
- making grout consistent color across room
- Painting tile
- Tile vs. Marble
- tile under appliances?
- cutting tiles around drain
- Countertops
- Saltillo tiles...
- Shower drain
- particle board over 2x6 tongue + grv
- Another Grouting Question
- Sealing framework behind vapor barrier?
- Custom tub/shower instructions
- Cement Backer Board?
- I think I goofed
- I just read a post that mention concrete and tile
- Modern day shower enclosures
- PVC Shower Pan
- Wall and floor tear off and replacement
- more radiant heat
- Rubber flooring and wind-generated electricity
- Ceramic floor tiling, very beginner questions
- help with unlevel travertine floor
- thanks john bridge!
- Novice Tiler
- Ceramic Tile Entryway
- Really noveice tiler!
- Blanke Edge trims; butt or leave space for grouting?
- HELP!! I need grout help
- Laying marble over tile
- Is it practical to remove tile from concrete?
- Sites for tile layout ideas?
- subfloor--fir or spruce, does it matter?
- HELP I need Help removing cured grout too
- wall, floor tile removal
- Breaking sharp edges on Porcelain
- Custom shower design questions/problems???
- Ceramic Tile Removal
- Tiling over plywood question
- Tile abuuting hardwood
- embedding hardiboard in shower deck mud???
- Making Mosaic Marble Dining Tops
- Ditra
- BEER- question about Ditra $
- Standard height for wall tiles????
- Grouting ceiling tile.
- installing different thickness tiles
- Laying Wonderboard on Slab?
- Buying tile online
- Chipping ceramic tile's glaze as Diamond wheel finishes cut thru.
- Tile grout
- Tile over paneling
- Vapor Barrier in showers?
- tile under/around toilet?
- Ditra and tile I!!
- Getting started...
- bud cline !!
- Caulk/Grout question
- Colouring Tile Grout
- bathroom remodel
- Kitchen floor replacement
- Ultimate "Tiling for Dummies" guide
vBulletin® v3.7.4, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
